You can get a fair amount more out or the injectors by upping the base fuel pressure. Some to the fastest (ETS for example) R35 GTRs are running smaller injectors with 90ish base pressure on a mechanical fuel pump. The fuel system gets more complicated the higher up you go, but the fuel atomizes better the higher you go as well, to a point.
~Induetime~ "Lag Less" First Stock Turbo to break 500WHP on boost alone. New track car project "Diseaze": http://arizonazproject.wordpress DOT com Custom fabrication for the Z32: search QFAB on Facebook More custom fabrication: search FuturFabrication on Facebook
